Гостей: 224
MarkII:
z94cu41dbfr332297 - буду благодарен
⊙ Z94CU41DBFR332297 - 2014/06/25 (RUSSIA)
RRUSPSBR14 SOLARIS 14(RUSSIA PLANT-RUS)
ENGINE : W61G(G4FCEW543603)
T/M : TQ01(NAEWA2011090)
SEAT :
INTERIOR : RY (BLACK)
EXTERIOR : PGU (CRYSTAL WHITE)
LEFT HAND DRIVE
WEATHER - THE FRIGID ZONE
SEDAN - 4DR 5P
1600 CC - GAMMA
DOHC - MPI
GASOLINE - UNLEADED
AUTO - 6 SPEED 2WD
ALL  AUDIO
S 0091A4 ENGINE PACKAGE - CVVT ENG
S 2531A1 RAD CORE MATERIAL - RESISTANT CACL2
S 2532B4 RAD LABEL - RUSSIA
S 2841B6 EMISSION REGULATION - EURO 4
S 2843A2 EVAP. GAS CONTROL - EURO-3
S 2911A2 UNDER COVER - W/O NOISE PAD
S 3111C7 FUEL TANK CAPACITY - 43 LITER
S 371CA1 BATTERY SAVER
S 3711A8 BATTERY CAPACITY - 60AH (20HR)
S 4371B3 AT KNOB - LEATHER WRAPPED
S 4503A1 SHIFT LOCK SYSTEM - MECHANICAL TYPE
S 529TA7 TOOL SET & JACK LABEL - EUROPE
S 5296C1 FULL SIZE WHL COVER - A TYPE
S 5411A1 FR SUSP TYPE - MACPH. W/COIL SPRING
S 5412A1 S/ABSORBER TYPE - OIL
S 5511A9 RR SUSP TYPE - TORSION AXLE
S 5512A1 S/ABSORBER TYPE - OIL
S 561AA1 W/ HEATED
S 5611B3 3-SPOKE - LEATHER
S 5631A4 STEER G COLUMN-MANUAL TILT & TELESCOPIC
S 569BE1 AIR BAG LABEL(PASS S) - PICTOGRAM
S 5691A3 DRIVER SIDE - DEPOWERED
S 5692A3 PASSENGER SIDE - DEPOWERED
S 5711A2 HPS(HYDRAULIC POWER STRG)
S 5811A3 FR BRAKE - DISC-14 INCH
S 5812A7 RR BRAKE - DISC-14 INCH
S 5891A2 ABS (ANTI LOCK BRK SYS)
S 5896A1 ESS (EMERGENCY STOP SIGNAL)
S 5911A2 SINGLE BOOSTER - 9 INCH
S 5972A1 P/BRAKE KNOB TRIM - SOFT PVC
S 5973A3 P/BRAKE PUSH BUTTON TRIM - CR COAT G
S 6501A1 HIGH GRADE
S 811AA1 HOOD INSULATOR
S 8123A2 TRUNK LID RELEASE TYPE - CABLE
S 8124A1 TRUNK LID TRIM - FULL COVER
S 8131A1 CENTRAL DR LOCK/UNLOCK - DR S CONTROL
S 8136A1 CHILD SAFETY RR DR LOCK G
S 8152A3 FUEL FILLER DR REL TYPE - CABLE
S 8191A2 KEY TYPE - INSIDE CUTTING
S 82A5A1 MAP POCKET-FR DR
S 82A7A1 MAP POCKET-RR DR
S 822AA1 DR BLACK OUT MATERIAL - TAPE
S 8233B1 CENTER TRIM - CLOTH(A TYPE)
S 8236A3 ARM REST COVER G - ARTIFICIAL LEATHER
S 8237A1 ARM REST HANDLE - PULL TYPE
S 8241A2 FR DR GLASS - TINTED
S 8245A2 RR DR GLASS - TINTED
S 8261A2 FINISH G - BODY COLOR
S 8262A2 LEVER FINISH G - CR COAT'G
S 834AA1 AUTO DOWN
S 834CA3 SAFETY WINDOW - FR DR(DRIVER S)
S 8341A2 POWER WINDOW(FR+RR)
S 8346A1 TIME LAG POWER WINDOW
S 8349A1 SW ILLUMINATION(ALL)
S 84FDA1 CTR AIR VENT
S 8421D3 N/PUNCH - HIGH VELOUR TYPE
S 8441A5 FR - PORTABLE
S 8445A1 CIGAR LIGHTER - W/O ILLUM.
S 8451A1 W/O LOCK
S 846BA1 W/ STORAGE BOX ARM REST - STD(1 DIN)
S 846CA1 CONSOLE TRAY - W/O FLOCK G
S 846EA1 POWER OUTLET
S 846LA1 CONSOLE COVER - CLOTH
S 8461A1 STD
S 8462A1 CUP HOLDER - FR(W/O ILL)
S 8481B6 GRAIN - HIGH GLOSSY
S 852GA1 VANITY MIRROR - GLASS TYPE
S 852HA1 VANITY MIRROR COVER
S 8521A1 MATERIAL - VINYL
S 8522A1 VANITY MIRROR - GLASS TYPE
S 8523A1 MATERIAL - VINYL
S 853AA2 RR - 2 EA
S 853JA2 RR - 2 EA
S 8531A2 ROOF TRIM MATERIAL - FABRIC
S 8532A1 FR - 1 EA
S 8561A1 RR P/TRAY MATERIAL - PLASTIC
S 857KA1 LUGGAGE UNDER TRAY
S 8571C1 LUGGAGE SIDE - W/PAPER
S 8573A2 FLOOR - WALL PAPER
S 86A1A1 W/ WIPER DEICER
S 8611B2 W/S GLASS TYPE-TINTED (W/ S/BAND)
S 8612A1 MLD G-WINDSHIELD - BLACK
S 863AAP CAR NAME - SOLARIS
S 863CA2 GRADE - GLS
S 8631A6 A TYPE - BLACK+CR COAT G
S 8641A1 TOWING HOOK
S 8642A1 TIE DOWN HOOK(LASHING)
S 8643A1 SHIPPING HOOK
S 8651B1 TYPE - 2.5 MILE
S 8652B1 COLOR - BODY COLOR
S 8681A1 MUD GUARD-FR
S 8682A1 MUD GUARD-RR
S 871BA1 RR HEATED W/ TIMER
S 8712B4 BACK LITE GLASS TYPE -TINTED(W/ HEATED)
S 8722A3 H.M.S.L - RR P/TRAY
S 8731C1 MLD G - CR COAT'G
S 8762C4 PASS S SIDE - ELECTRIC HTD-CONV
S 8763C4 DRIVER S SIDE - ELECTRIC HTD-CONV
S 8765A2 COLOR - BODY COLOR
S 8811C1 CLOTH - CLOTH
S 8821A1 HEAD REST - UP/DOWN
S 8823A1 SLIDING
S 8824A2 DOUBLE RECLIN G
S 8825A4 ADJUSTER - PUMP G DEVICE
S 8838A1 SEAT WARMER(HEATER)
S 885DA1 SLIDING
S 885EA2 DOUBLE RECLIN G
S 8854A1 HEAD REST - UP/DOWN
S 886BA1 SEAT BACK - SEAT BACK POCKET
S 8873A1 SEAT WARMER
S 888AA2 PRE TENSIONER - ELECTRICAL TYPE
S 888DA1 SEAT BELT REMINDER
S 888KA2 S/BELT ANCHOR - ADJUSTABLE
S 888RA2 S/BELT ANCHOR - ADJUSTABLE
S 8881B1 DRIVER S SIDE - ELR
S 8884D1 PASSENGER S SIDE - ELR
S 8885A2 RETRACTOR PRETENSIONER - ELECTRICAL TYPE
S 8912D1 6:4 SPLIT BACK FOLD G - BACK
S 8913A1 LH
S 8914A1 RH
S 892DA1 HOLDER - UPR ANCHOR
S 892GA1 LWR ANCHOR
S 8981A4 SIDE - ELR
S 8982A4 CTR - ELR
S 921BA1 LEVELING DEVICE - MANUAL
S 9222A1 RR - CONVENTIONAL
S 923DA1 ONE TOUCH TRIPLE TURN SIGNAL
S 9231B1 INTEGRATED - CLEAR LENS
S 928FA1 CTR - GLOW LAMP
S 928KA1 DELAY OUT INTERIOR LAMP
S 928WA1 BULB TYPE - 1 BULB
S 9282A1 FR - W/ SUNGLASSES
S 9287A1 LUGGAGE LAMP
S 94C1A1 A/T POSITION INDICATOR
S 94C6A1 DIRECTION INDICATOR
S 94C7A1 OIL PRESSURE
S 94C8A1 BRAKE OIL
S 94C9A1 PARK G BRAKE
S 94D0A1 DR AJAR - DR AJAR
S 94D1A1 BATTERY CHARGE
S 94D2A1 HIGH BEAM
S 94D4A1 LOW FUEL
S 94D7A1 TRUNK LID(T/GATE) OPEN
S 94D9A1 CHECK ENGINE
S 94E3A1 SEAT BELT
S 94E5A1 A.B.S
S 94E6A1 A/BAG
S 94F1A1 A/T OD'POSITION INDICATOR
S 94G0A1 LOW WASHER FLUID
S 94G4A1 FR FOG LAMP
S 94H6A1 IMMOBILIZER
S 94M0A1 SPEEDOMETER TYPE - KMPH
S 94N0A1 TEMPERATURE UNIT - C
S 94X2A1 ECO INDICATOR
S 940AA3 TRIP ODOMETER - LCD
S 940BA1 TACHOMETER
S 940CA1 FUEL
S 940DA1 WATER TEMP.
S 940EA1 LCD ODO/TRIP METER
S 9401B1 CLUSTER TYPE - SUPER VISION
S 9402A1 SPEEDOMETER
S 9451A1 TYPE - DIGITAL
S 9491A1 RHEOSTAT
S 9541A1 BODY CONTROL MODULE - BCM(ETACS)
S 9542A1 IMMOBILIZER
S 9552A2 BLUE TOOTH (AUDIO)-W/ VOICE RECOGNITION
S 9571A3 RR PARK G ASSIST SYSTEM(RPAS)
S 9611NK RADIO+CD+MP3+RDS - PA30A R
S 9614B1 COMPONENT- 2 DIN
S 9618A1 USB+AUX
S 9621K1 ANTENNA TELESCOPIC - ANTENNA MICRO
S 963CA1 SPEAKER LOCATION FR DR - GENERAL
S 963KA1 SPEAKER LOCATION TWEETER-FR DR UPR
S 963ZA1 SPEAKER LOCATION RR DR LOW-GENERAL
S 965QA1 O/SIDE TEMPERATURE DISPLAY
S 9661A1 SINGLE HORN
S 967AA1 AUDIO REMO.
S 967EA1 BLUE TOOTH REMO
S 967FA1 VOICE RECOGNITION SYSTEM REMO
S 9711A2 BLOWER - 4 SPEED FAN
S 9721A2 CABLE TYPE - ROTARY TYPE
S 9741A1 RR HEATING DUCTS - 2ND SEAT
S 9761A3 FR COOLER - FULL AUTO A/CON
S 981AA1 FR WIPER-2 SPEED
S 9811A2 FR WIPER - INTERMITTENT(VARIABLE)
S 9819A2 BLADE TYPE - AERO
S 9852A1 FUNCTION - WASHER FLUID LEVEL SENSOR
O 5291KB AL WHEEL 6.0J * 16 - B TYPE
O 5293ET 195 TIRE - 195/55 R16
O 5297A3 FULL SIZE 1EA - AL WHEEL & TIRE
O 813BA1 IMPACT SENS G AUTO DR UNLOCKG
O 813DA1 IGN KEY REMINDER
O 819HA1 SMART KEY-FR DR
O 8196A2 BUTTON START - BUTTON W/ ILLUMINATED
O 8198A3 STEER G LOCK TYPE - ESCL
O 8511G3 ECM+REAR DISPLAY TYPE
O 876NA1 SIDE REPEATER LAMP (O/S MRR)
O 921JA1 ESCORT
O 9211F5 PROJECTION - BI-FUNCTION(HIGH/LOW)
O 9213A4 DRL - DEDICATED LED TYPE
O 9221A2 CONVENTIONAL - CLEAR LENS
O 9241A3 RR COMBI LAMP - LED TYPE
O 9511A1 AUTO LIGHT CONTROL SYSTEM - 1 STAGE
O 9652A1 BACK WARN G CAMERA
Беларусь
Z94CT41DAFR372617 Буду очень благодарен.
oleg6782:
⊙ Z94CT41DAFR372617 - 2014/11/19 (RUSSIA)
ENGINE : W51G(G4FCEW621172)
T/M : ZG87(ZG87EJ418362)
SEAT :
EXTERIOR : RHM (SLEEK SILVER)
LEFT HAND DRIVE
SEDAN - 4DR 5P
1600 CC - GAMMA
DOHC - MPI
GASOLINE - UNLEADED
MANUAL T/M - 6 SPEED 2WD
ALL  AUDIO
S 4161A2 CLUTCH TYPE - HYDRAULIC
S 4501A1 CLUTCH LOCK
S 5291C3 STEEL WHEEL - 6.0J * 15
S 5293DB 185 TIRE - 185/65 R15
S 5297A1 FULL SIZE 1EA - STEEL WHEEL & TIRE
S 6501A1 HIGH GRADE
S 8236A7 ARM REST COVER G - PLASTIC
S 8262A3 LEVER FINISH G - METAL PAINT
S 834AA1 AUTO DOWN
S 8451A1 W/O LOCK
S 8461A1 STD
S 8481A6 GRAIN - METAL PAINT
S 8511B1 DAY/NIGHT TYPE
S 853AA2 RR - 2 EA
S 853JA2 RR - 2 EA
S 8532A1 FR - 1 EA
S 863CA1 GRADE - GL
S 8731B1 MLD G - BODY COLOR
S 8823A1 SLIDING
S 885DA1 SLIDING
S 8913A1 LH
S 8914A1 RH
S 892GA1 LWR ANCHOR
S 8981A4 SIDE - ELR
S 8982A4 CTR - ELR
S 9211E3 MFR - CLEAR
S 9213A3 DRL - DEDICATED BULB TYPE
S 9232A1 CONVENTIONAL - CLEAR LENS (ON FENDER)
S 9241A1 RR COMBI LAMP - CLEAR
S 94C8A1 BRAKE OIL
S 94D2A1 HIGH BEAM
S 94D4A1 LOW FUEL
S 94E3A1 SEAT BELT
S 94E5A1 A.B.S
S 94E6A1 A/BAG
S 94X6A1 M/T SHIFT INDICATOR
S 940BA1 TACHOMETER
S 940CA1 FUEL
S 9401C1 CLUSTER TYPE - CONVENTIONAL
S 9761A1 FR COOLER - MANUAL A/CON
S 9819A1 BLADE TYPE - CONVENTIONAL
O 371CA1 BATTERY SAVER
O 4371A3 MT KNOB - LEATHER WRAPPED
O 561AA1 W/ HEATED
O 5611B3 3-SPOKE - LEATHER
O 5631A4 STEER G COLUMN-MANUAL TILT & TELESCOPIC
O 819CA1 KEYLESS ENTRY-T/OPEN
O 8194B3 TYPE - FOLDING
O 8233B1 CENTER TRIM - CLOTH(A TYPE)
O 8261A2 FINISH G - BODY COLOR
O 834CA3 SAFETY WINDOW - FR DR(DRIVER S)
O 8341A2 POWER WINDOW(FR+RR)
O 8346A1 TIME LAG POWER WINDOW
O 846BA1 W/ STORAGE BOX ARM REST - STD(1 DIN)
O 846LA1 CONSOLE COVER - CLOTH
O 8611H3 W/S GLASS TYPE-HEATED WIRE-TINTED(W/O S/
O 8762C4 PASS S SIDE - ELECTRIC HTD-CONV
O 8763C4 DRIVER S SIDE - ELECTRIC HTD-CONV
O 8765A2 COLOR - BODY COLOR
O 8838A1 SEAT WARMER(HEATER)
O 8873A1 SEAT WARMER
O 8912D1 6:4 SPLIT BACK FOLD G - BACK
O 9282A1 FR - W/ SUNGLASSES
O 9541A1 BODY CONTROL MODULE - BCM(ETACS)
O 9571A3 RR PARK G ASSIST SYSTEM(RPAS)
O 9611NK RADIO+CD+MP3+RDS - PA30A R
O 9614B1 COMPONENT- 2 DIN
O 9618A1 USB+AUX
O 967AA1 AUDIO REMO.
Чебоксары
Здравствуйте. Расшифруйте пожалуйста z94cu41cbfr365670
shum:
⊙ Z94CU41CBFR365670 - 2014/10/27 (RUSSIA)
ENGINE : W14G(G4FAEW630264)
T/M : UT63(FE1AU142159)
SEAT :
EXTERIOR : M2B (MISTY BEIGE)
LEFT HAND DRIVE
SEDAN - 4DR 5P
1400 CC - GAMMA
DOHC - MPI
GASOLINE - UNLEADED
AUTO - 4 SPEED 2WD
ALL  AUDIO
S 561AA1 W/ HEATED
S 6501A1 HIGH GRADE
S 819CA1 KEYLESS ENTRY-T/OPEN
S 8194B3 TYPE - FOLDING
S 834AA1 AUTO DOWN
S 8451A1 W/O LOCK
S 8461A1 STD
S 853AA2 RR - 2 EA
S 853JA2 RR - 2 EA
S 8532A1 FR - 1 EA
S 8823A1 SLIDING
S 885DA1 SLIDING
S 8913A1 LH
S 8914A1 RH
S 892GA1 LWR ANCHOR
S 8981A4 SIDE - ELR
S 8982A4 CTR - ELR
S 94C8A1 BRAKE OIL
S 94D2A1 HIGH BEAM
S 94D4A1 LOW FUEL
S 94E3A1 SEAT BELT
S 94E5A1 A.B.S
S 94E6A1 A/BAG
S 940BA1 TACHOMETER
S 940CA1 FUEL
S 9491A1 RHEOSTAT
S 9618A1 USB+AUX
Чебоксары
Здравствуйте. Расшифруйте пожалуйста z94ct41dbfr385726. Спасибо
shum:
⊙ Z94CT41DBFR385726 - 2014/12/29 (RUSSIA)
ENGINE : W61G(G4FCEW666892)
T/M : TQ01(NAEWA2287313)
SEAT :
EXTERIOR : MZH (PHANTOM BLACK)
LEFT HAND DRIVE
SEDAN - 4DR 5P
1600 CC - GAMMA
DOHC - MPI
GASOLINE - UNLEADED
AUTO - 6 SPEED 2WD
ALL  AUDIO
S 4371B1 AT KNOB - SOFT PVC
S 5611B2 3-SPOKE - POLY URETHANE
S 5631A3 STEER G COLUMN-MANUAL LWR TILT
S 6501A1 HIGH GRADE
S 8261A1 FINISH G - BLACK COLOR
S 834AA1 AUTO DOWN
S 8451A1 W/O LOCK
S 8461A1 STD
S 853AA2 RR - 2 EA
S 853JA2 RR - 2 EA
S 8532A1 FR - 1 EA
S 863CA1 GRADE - GL
S 8765A1 COLOR - BLACK
S 8823A1 SLIDING
S 885DA1 SLIDING
S 8913A1 LH
S 8914A1 RH
S 892GA1 LWR ANCHOR
S 8981A4 SIDE - ELR
S 8982A4 CTR - ELR
S 9282A2 FR - W/0 SUNGLASS
S 94C8A1 BRAKE OIL
S 94D2A1 HIGH BEAM
S 94D4A1 LOW FUEL
S 94E3A1 SEAT BELT
S 94E5A1 A.B.S
S 94E6A1 A/BAG
S 940BA1 TACHOMETER
S 940CA1 FUEL
O 86A1A1 W/ WIPER DEICER
O 9618A1 USB+AUX
Здравствуйте, подскажите какая у меня комплектация, если в расшифровке VIN-кода стоит Уровень оснащения (комплектации) Делюкс
VIN: Z94CT41CBBR005888
Заранее спасибо
Alexandr:
Заранее спасибо
⊙ Z94CT41CBBR005888 - 2011/02/04 (RUSSIA)
RRUSPSBR11 SOLARIS 11(RUSSIA PLANT-RUS)
ENGINE : W16G(G4FAAW202832)
T/M : UT44(AA1YU528207)
SEAT :
EXTERIOR : SAE (CARBON GRAY)
LEFT HAND DRIVE
SEDAN - 4DR 5P
1400 CC - GAMMA
DOHC - MPI
GASOLINE - UNLEADED
AUTO - 4 SPEED 2WD
ALL  AUDIO
S 2843A7 EVAP. GAS CONTROL - EURO-4
S 6501A1 HIGH GRADE
S 8236A1 ARM REST COVER G - PVC
S 834AA1 AUTO DOWN
S 8451A1 W/O LOCK
S 8461A1 STD
S 853AA2 RR - 2 EA
S 853JA2 RR - 2 EA
S 8532A1 FR - 1 EA
S 863CA1 GRADE - GL
S 8631A5 A TYPE - BODY COLOR+CR COAT G
S 8823A1 SLIDING
S 885DA1 SLIDING
S 8912A2 FOR 3 PEOPLE - BENCH-FIXED
S 8913A1 LH
S 8914A1 RH
S 892GA1 LWR ANCHOR
S 8981A4 SIDE - ELR
S 8982A4 CTR - ELR
S 9213A2 DRL - EUROPE TYPE
S 94C8A1 BRAKE OIL
S 94D2A1 HIGH BEAM
S 94D4A1 LOW FUEL
S 94E3A1 SEAT BELT
S 94E5A1 A.B.S
S 94E6A1 A/BAG
S 940BA1 TACHOMETER
S 940CA1 FUEL
S 9611A2 BLANK G COVER - GERMANY TYPE
S 9614A2 COMPONENT 1 DIN - W/ TRAY
S 9621G1 ANTENNA TELESCOPIC - ANTENNA ROOF TYPE
O 569BD4 PASS S - D LANGUAGE
O 5692A3 PASSENGER SIDE - DEPOWERED
O 5812A7 RR BRAKE - DISC-14 INCH
O 5891A2 ABS (ANTI LOCK BRK SYS)
O 5896A1 ESS (EMERGENCY STOP SIGNAL)
O 9761A1 FR COOLER - MANUAL A/CON
ЗДРАВСТВУЙТЕ!ПРОБЕЙТЕ ПОЖАЛУЙСТА МОЙ VIN Z94CU41DBBR052368
Приветствую Вас! Пробейте, пожалуйста, по VIN Z94CT41CAFR320198, буду очень благодарен.
Андрей:
⊙ Z94CU41DBBR052368 - 2011/07/22 (RUSSIA)
ENGINE : W26G(G4FCBW297792)
T/M : UT44(AB1YU722124)
SEAT :
LEFT HAND DRIVE
SEDAN - 4DR 5P
1600 CC - GAMMA
DOHC - MPI
GASOLINE - UNLEADED
AUTO - 4 SPEED 2WD
ALL  AUDIO
S 569BD4 PASS S - D LANGUAGE
S 6501A1 HIGH GRADE
S 813BA1 IMPACT SENS G AUTO DR UNLOCKG
S 813DA1 IGN KEY REMINDER
S 834AA1 AUTO DOWN
S 8451A1 W/O LOCK
S 8461A1 STD
S 853AA2 RR - 2 EA
S 853JA2 RR - 2 EA
S 8532A1 FR - 1 EA
S 8823A1 SLIDING
S 885DA1 SLIDING
S 8913A1 LH
S 8914A1 RH
S 892GA1 LWR ANCHOR
S 8981A4 SIDE - ELR
S 8982A4 CTR - ELR
S 9221A2 CONVENTIONAL - CLEAR LENS
S 94C8A1 BRAKE OIL
S 94D2A1 HIGH BEAM
S 94D4A1 LOW FUEL
S 94E3A1 SEAT BELT
S 94E5A1 A.B.S
S 94E6A1 A/BAG
S 940BA1 TACHOMETER
S 940CA1 FUEL
S 9611NG RADIO+CD+MP3+RDS - PA 710R
S 9618A1 USB+AUX
O 9401B1 CLUSTER TYPE - SUPER VISION
O 9491A1 RHEOSTAT
avtoexpert_444:
⊙ Z94CT41CAFR320198 - 2014/05/20 (RUSSIA)
ENGINE : W08G(G4FADW772318)
T/M : ZG82(TEJ5 F678626)
SEAT :
LEFT HAND DRIVE
SEDAN - 4DR 5P
1400 CC - GAMMA
DOHC - MPI
GASOLINE - UNLEADED
MANUAL T/M - 5 SPEED 2WD
ALL  AUDIO
S 4371A1 MT KNOB - SOFT PVC
S 6501A1 HIGH GRADE
S 834AA1 AUTO DOWN
S 8451A1 W/O LOCK
S 8461A1 STD
S 853AA2 RR - 2 EA
S 853JA2 RR - 2 EA
S 8532A1 FR - 1 EA
S 863CA1 GRADE - GL
S 8823A1 SLIDING
S 885DA1 SLIDING
S 8913A1 LH
S 8914A1 RH
S 892GA1 LWR ANCHOR
S 8981A4 SIDE - ELR
S 8982A4 CTR - ELR
S 94C8A1 BRAKE OIL
S 94D2A1 HIGH BEAM
S 94D4A1 LOW FUEL
S 94E3A1 SEAT BELT
S 94E5A1 A.B.S
S 94E6A1 A/BAG
S 940BA1 TACHOMETER
S 940CA1 FUEL
O 9618A1 USB+AUX
Редактировалось: 1 раз (Последний: 15 февраля 2015 в 18:53)
Андрей:
SEAT :
LEFT HAND DRIVE
SEDAN - 4DR 5P
1600 CC - GAMMA
DOHC - MPI
GASOLINE - UNLEADED
AUTO - 4 SPEED 2WD
ALL  AUDIO
S 6501A1 HIGH GRADE
S 834AA1 AUTO DOWN
S 8451A1 W/O LOCK
S 8461A1 STD
S 853AA2 RR - 2 EA
S 853JA2 RR - 2 EA
S 8532A1 FR - 1 EA
S 8823A1 SLIDING
S 885DA1 SLIDING
S 8913A1 LH
S 8914A1 RH
S 892GA1 LWR ANCHOR
S 8981A4 SIDE - ELR
S 8982A4 CTR - ELR
S 94C8A1 BRAKE OIL
S 94D2A1 HIGH BEAM
S 94D4A1 LOW FUEL
S 94E3A1 SEAT BELT
S 94E5A1 A.B.S
S 94E6A1 A/BAG
S 940BA1 TACHOMETER
S 940CA1 FUEL
S 9618A1 USB+AUX
O 9491A1 RHEOSTAT
Санк-Петербург
Здравствуйте, расшифруйте пожалуйста Z94CT41CBFR373456
mg:
⊙ Z94CT41CBFR373456 - 2014/11/21 (RUSSIA)
ENGINE : W14G(G4FAEW637382)
T/M : UT63(FE1AU015937)
SEAT :
LEFT HAND DRIVE
SEDAN - 4DR 5P
1400 CC - GAMMA
DOHC - MPI
GASOLINE - UNLEADED
AUTO - 4 SPEED 2WD
ALL  AUDIO
S 6501A1 HIGH GRADE
S 8233A1 CENTER TRIM - PLASTIC(NO COVER G)
S 834AA1 AUTO DOWN
S 8341A1 POWER WINDOW(FR)
S 8451A1 W/O LOCK
S 8461A1 STD
S 853AA2 RR - 2 EA
S 853JA2 RR - 2 EA
S 8532A1 FR - 1 EA
S 863CA1 GRADE - GL
S 8823A1 SLIDING
S 885DA1 SLIDING
S 8913A1 LH
S 8914A1 RH
S 892GA1 LWR ANCHOR
S 8981A4 SIDE - ELR
S 8982A4 CTR - ELR
S 94C8A1 BRAKE OIL
S 94D2A1 HIGH BEAM
S 94D4A1 LOW FUEL
S 94E3A1 SEAT BELT
S 94E5A1 A.B.S
S 94E6A1 A/BAG
S 940BA1 TACHOMETER
S 940CA1 FUEL
Добрый день. Будьте так добры, расшифруйте пожалуйста.
Z94CU51DBCR050015
бекас:
Зравствуйте, уважаемые форумчане.
В этой теме я пробью на коплектацию и дату изготовления VIN любого Соляриса. Впрочем не только Соляриса, но и любого Hyundai и KIA, сошедшего с конвейеров компании.
Зачем это надо?
Некоторые просто хотят узнать ДР своего автомобиля, ну а некоторые без такой информации не смогут подобрать правильную запчасть.
Собственно Welcome!
Единственное о чем хотел предупредить...
Данная тема - публичная, результат буден виден непосредственно тут. В ЛС VIN не пробиваю, извините.
Привет! Помоги узнать комплектацию Solaris модели 2015 года Z94CT41DBFR354650
Вообще нужен потолок! Спасибо большое!
Добрый день! Можно получить расшифровку? VIN:Z94CT41CBBR027808
Нск
Добрый день. Беру новый Солярис. Буду очень признателен за информацию об истории моего автомобиля VIN Z94CU41DBFR420179. Заранее благодарен. car
Я больше не пробиваю VIN - нет возможности, извините...
Тема пока закрыта!
